It is currently 19 Jul 2018 07:47
Farina newbie
Come on in and say hello.
  • Author
  • Message
Offline
level7
Re: Farina newbie
Post02 May 2016 09:26
So done some investigating and I can get caliper mounts made to bolt onto the drum stubs so just need to do some measuring and hopefully can have a solution soon to fit any aftermarket mini disk brakes (pcd is same as the farina so just need to check bearing size availability) this would mean I can fit 8.4" vented 4 pots from minisport 8-)
Offline
dave the rave
Site Admin
Re: Farina newbie
Post03 May 2016 15:40
Still think it'll be a lot more straightforward fitting Midget gear. All available over here, a bit expensive to get it i know, but all straight bolt on.
In my opinion, 8.4" vented discs and 4 pot calipers are way over the top............unless you're fitting a tuned/modded V8 etc.
Offline
level7
Re: Farina newbie
Post04 May 2016 21:22
By using caliper brackets it outs still a "bolt on swap" for me to get the parts needed for the spridget swap here in nz will cost almost double what the mini kit does by time I have recond all the second hand parts. As far as the vented 4pots being over the top they are pretty much standard fare on minis with a 1275 fitted in fact they were factory fitted to metros which are both smaller lighter cars than the .
Offline
dave the rave
Site Admin
Re: Farina newbie
Post05 May 2016 12:58
Ah, fair enough. Didn't realise the 4 pots were the Metro ones. ( Shoulda known....i've chuffin got one.......... :oops: :oops: ).
That being the case, obviously far cheaper than air freighting Midget bits, which, as you say, will all need reconning !
Offline
level7
Re: Farina newbie
Post11 May 2016 10:38
Ok update, I was talking with a local mini morris mg guru today and he told me he used to race an a 40 farina which he fitted daimler disk brakes to (the old 2.5v8 car ones). Custom caliper mounts have been priced and are around $100 nz dollars so looking good, I can probably get mounts made to match the mounting position of the spridget brakes then I can just get disks etc to suit over here.
Previous
Return to Welcome
Who is online
Users browsing this forum: No registered users and 0 guests
cron
